ford forus anyone? think before buying it
Publié : mer. août 16, 2006 11:22 am
ca c'est le commentaire d'un propriétaire
-Brakes require replacing at least twice a year and wear abnormally fast. Noisy.
-Cruise control spring dropped out onto the pedals just after warranty ran out. Dealer would not repair and suggested it would be extremely expensive to do so.
-Heater fan packed it in this week.
-Cooling system problems that cannot be identified by a mechanic.
-Excessive tire wear. No identified source.
-Within first four months of ownership, electrical system shorted out and left me stranded.
-The power windows work and then stop.
-Have had four sets of tires on car due to front problems.
-The ignition just went bad so the key does not turn to start the car at 87k.
-Mysterious leaks from under the dash when it rains.
-Fit and finish is not the greatest, but this I've come to expect from any American manufacturer.
-Wheel bearings in back tires went bad at 45,000 miles. Was covered under recall though...whew!
-Paint finish on passenger side door frame seems to be fading. Black turning gray.
-Had a problem with battery leaking acid onto support platform underneath. Had to get various hoses underneath replaced and new battery due to acid leakage.
-Rubber around windshield washers at top of hood hardened and are now starting to crumble away.
-Rubber at base of antenna hardened and crumbled away exposing spring to the elements (it's now rusty...I'll have to replace the antenna soon).
-All four doors make HORRIBLE "wrenching" sounds when opened and closed. Friends think this is highly amusing.
-One of my fuses recently went... the one that controls the power locks and remote locking key fob. Interestingly enough, the fuse is located on the BACK of the fusebox. I laughed out loud at that one.
-The driver side rear power window sometimes goes up... and sometimes doesn't. Although lately it's been playing nice with me.
-The switch that controls the speed of the air conditioning fan is starting to go...it's hard to turn smoothly, and is rubbing the black paint behind it off.
-The driver side seat has a larger gap between the back cushion and the seat cushion. You can see straight through it to the rear passenger floor. Not so on the passenger side. Weird.
-The shocks or struts are starting to go, and the car makes some strange noises when turning. Especially to the right.
-The radio turns off and on by itself. You have to push on the front control panel to get it to come back on. The lights behind the preset numbers don't always work.
-The lights behind the LED odometer have an uneven appearance... some dark splotches. You'd have to see it to believe it. Also very weird.
fiable !
fiable !
