. . ENGINE . . . /¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
:: -Exhaust 2.25 Straight
:: -Cataliseur magnaflow carsound
:: -OBX Twin-Loop Muffler
:: -OBX Cold Air Intake
:: -OBX Hose Radiateur Bleu
:: -OBX Ground Wire Kit (7x4gauge)
:: -OBX 10.3mm Spark Plug Wire
:: -92-96 Prelude Shifter Cable Swap
:: -Power Steering Enlevé
:: -Balancer Belt Enlevé
:: -Thermostat Enlevé
:: -Chaufrette Switch Bypassé (Directe)
:: -Wire Tucking Complet Sauf FuseBox
:: -MAP sensor Relocalisé
:: -Systeme PowerSteering Enlevé
:: -Systeme WindShield Washer Enlevé
:: -Baterie Dans la valise
:: -EGR block off plate
:: -Air Boost Valve Enlevé
:: -BlackBox Mistere Enlevé
:: -Ecu PT6
:: -Plenum F22A6
:: -Runner F22B
:: -Headers/Downpipe 4-2-1 EX
:: -DIY IAB Spacer
:: -DIY Catch Can (CampBell Hausfeld)
:: -DIY Prestone Overflow Can
:: -DIY Throttle Body Coolant Bypass
. . EXTERIOR . . . /¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
:: -Front Bumper Cover: @ Secret @
:: -Rear Bumper Cover: BudyClub
:: -Side Skirt: M3
:: -JDM Front Bumper (aucun renfort)
:: -Elargissement 1/2 Pouce Ailes Avant
:: -Elargissement 1 1/2 Pouce Ailes Arrieres
:: -JDM Conversion Lumiere Avant @ Secret @
:: -Custom Altezza (Skyline GT-R33 "95 Like) Tail Light
:: -Ailes Avant fibre de verre Avec Trapes
:: -Ailes Arriere fibre de verre custom
:: -Hood Avec Scoop Custom Mack 1
:: -Moulure Half Shaved
:: -Antenne Replacé 45degré Sur le toit
:: -Valise Shavé Custom
:: -Eye Lid Custom FiberGlass Moulé Au Hood
:: -Teintage Des Vitres A 80% Onyx
:: -Kit H.I.D 8000K
:: -Moulure chromé BackGlass/Windshield ExR 90-91 2portes
:: -Couvert de valve Peinturé
:: -Couvert Timing Belt Coupé 45Deg
:: -Hyundai Santa Fee Hood Shock
. . Stiff Stuff, Stoppers, and Rollers. . . . /¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
:: -NSX 95 2pistons Front Calipers
:: -Accord 1992 Exr Rear Disk Conversion
:: -EBC Slotted 11.1 Front Wagon Rotor
:: -Brembo Plain Rear Rotor
:: -Pad Hawk Hp+ au 4coins
:: -Civic 92 4040 Proportion Valve
:: -Front No-Name Strut Bar
:: -Honda Brand New Front Bushing
:: -5Zigen Copse 17"x7.5"
. . INTERIOR . . . /¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
:: -Swap Electrique Exr [Thx Dom]
:: -Switch EDM Rear Fog Light
:: -Banc civic 2005 (Flambette)
:: -Isolation B-Quiet
. .: -Toit
. .: -Porte
. .: -Planché
. .: -Compartiment arriere
. .: -Valise
. .: -Couvent De Valise
:: -Tapis Interieur Neuf (Bleu Royal)
:: -Peinturé Noir Reflet Bleu/Vert
:: -Interieur Suede Graphite/Artique
:: -Peinturé Noir Reflet Bleu/Vert:
. .: Plastic Des Portes
. .: Plastique Console
. .: Plastique trim Arriere
. .: Dash
. .: 1/2 Premiere Parti Console Centrale
:: -Peinturé Bleu Metalique
. .: Trim De Console
. .: Gauge Bezel
. .: Cover De Boite A Gant
:: -Suede
. .: Toit
. .: Trim De Porte
:: -Cadrant EuroLite Blanc Indogo (Custom By D.O.T.)
:: -OBX Triple Gauge Pod
:: -Shift Knob Ractive "8Led Light Bleu"
:: -E-brake Ractive Black Carbone
:: -Console Centrale EXR (90-91 Canada Uniquement)
:: -Volant 350mm" Mugen (IMI) + Quick Release
:: -Heavy Duty Fog Light Wiring Kit
:: -Porte-verre Exr
. . AUDIO . . . /¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
:: -Radio PIONEER Premier DEH-P980BT
:: -Ampli Eclipse DA6213
:: -Caisse BassWorx BGP212 Isolé-Renforcé
:: -2 Sub 12" CDT AUDIO 800W Dual Voice-Coil
:: -2 Speaker 6.5" CDT HD62 175wRms
:: -2 Tweeter CDT
:: -2 Crossover: SatNet 480 24 dB Elliptic 2-way
:: -2 Condensateur VooDoo 2.4Farad Digital Bleu
:: -Filage VooDoo 0 Gauge Crystal Purple hexagon
:: -Battery 0/2/4/8G Platinum Terminal
:: -All Around VooDoo Platinum Terminal
:: -Alternateur Exr 130amp Boosté
:: -Optima BlueTop Marine deepcycle Battery
. . TURBO PROJECT . . . /¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
:: -Tete F22B Full Port/polish
:: -Base F22A1 En Beton
:: -Throttle Body H22A
:: -valve 2mm Oversize
:: -Retainer Planinum
:: -CamShaft Agressif
:: -Eagle Rod
:: -Piston Forgé Wiseco 8.1:1 Compression
:: -Je Piston ring
:: -Big BOre Sleeve Forgé oversize a 89mm
:: -Turbo garrett 15-20psi
jai hate de voir la suite et surtout, la voir en vrai
de kessé
mais beau projet
