Moderators: Guillaume, Usul, Modérateurs
Forum rules
NoRmAlGuy
oups
95exrv6
If you go out and get brembo slotted or drilled OE spec rotors with Hawk or PBR pads and you go on a track for racing, you'll have a certain about of brake FADE (vibration, heating up) The calipers are mounted and designed for everyday use.
There are a few options for Brake Upgrades for the 90-97 accord but most are over 1000$
PowerSlot has the cheapest Big Brake Kit.
You can you the OE Caliper, but all the rest is swapped
less then 500$ and you get up to 30 % larger surface then stock 90-97 accord
'Power Slot Big Rotor Brake Kit allows for use of the Original Equipment brake caliper, making it the most affordable big rotor system on the market.
Power Slot rotors have an average 20-percent larger surface area and can reduce a vehicle's stopping distance by up to 33 percent.
These oversized Power Slot rotors also increase brake torque for reduced pedal effort and have a greater thermal capacity that extends performance during continuous hard braking.
The Power Slot Big Rotor Brake Kit includes caliper repositioning brackets, complete Premium Grade and aircraft-quality hardware. **17" or larger wheel recommended for installation.'
Rotara has a Big Brake kit too, for 1200$
'Rotora big brake Package includes two cross-drilled and slotted vented e-coated black rotors
The Rotora two 2-pc cast aluminum 4-piston calipers, two anodized black caliper mounting brackets, Rotora street performance pads, stainless-steel braided brake lines.
Note: All 330mm discs require a minimum of 17in size wheels.'
Brembo Big Brake Kit - 2000$ but you have 14.4" discs !!! or go full out and get the Brembo Grand Toursimo kit which are fix mounted calipers.
Brembo Big Brake also has just 13" front drilled for 400-500$
Speak to pierre luc about the options.
Most people will not want to pay for brakes. But most people will complain about brakes heating up as well. You CANNOT expect to race like you can in grand tourismo with OE braking system.
I do not race / track my car, so the Crossdrilled setup with New calipers all around is perfect. Using 'old' OEM calipers can also hurt your braking as the pistons might almost worn out or seized.
Other rides
10 Odyssey
04 Civic LX - scrapped
93 Civic SI - Projet
95 Accord V6 Manual - sold
96 Accord EX - sold
98 Odyssey EX - sold
92 Accord EX - scrapped
92 Civic EX - scrapped
10 Odyssey
96 Accord EX - sold
NoRmAlGuy
faut pas venir fou aussi la ... ya moyen de faire de quoi avec des freins de 11 pouces qu'on retrouve sur les prélude Sr-V ou meme Sr/S ferrais la job.
NoRmAlGuy
tout le monde on été répondu.
Bumps.
Bumps.
check tes emails ma ptite chouette !!!
Un GROS Merci pour les pièces et le chemin du retour, j'ai sauvé énormément de temps pour revenir chez moi.
NoRmAlGuy
oui surement ... le pont jacques cartier y a jamais personne le dimanche soir a compagnie au pont champlain!
Merci beaucoup Pierre-Luc pour les pièces, très bon service, shipping extra vite, qualité au rendez-vous! Merci encore et oui c'est très efficace pour le prix!
NoRmAlGuy
donc tout a fité #1.
Super!
Super!
NoRmAlGuy
je voulais vous dire que je vais surement pas aller a l'épluchette .. a moins ca soit le dimanche
double post o_0
Ca aiderais si tu posterais dans le bon thread. Autrement si j'aurais pas eu rien à faire déjà pour le reste de ma journée j'aurais pas vu ton post!
C'est bel et bien le samedi, et sens toi pas mal on sera vraiment pas beaucoup cette année. Avantage; ca fera pas plein de petite gang!
Ceci dit à moins d'un empêchement de notre part ca sera toujours le samedi et à la fin de semaine de l'action de grâce pour les années à venir(comme celles passés).
NoRmAlGuy
t'inquiete si j'ai un lousse entre 14h00 et 17h00 m'as passé faire mon tour ... en passant j'ai écris ici parce que je sais qui a plein de monde qui surveille mes treads
lol comme toi ! hahahaha... maudit que j'ai un bon ange gardien
A plus badpiston tu diras salut a j-f le grand travailleur pour moi !
lol comme toi ! hahahaha... maudit que j'ai un bon ange gardien A plus badpiston tu diras salut a j-f le grand travailleur pour moi !
NoRmAlGuy
meme pas plus y aller ...
NoRmAlGuy
s'Est ma fete ( 21 septembre)
DeeAzn83
tres bon gars j'ai recu mon kit tres rapidement
tu commendant et tu la presque tout de suite lol
jai juste pas eu le temp de les poser encore!
DeeAzn83
en passent jai installer mes brake
perfect fit ta trouver les bon
pis ton produit anti-rouolle ca marche ya pas pas une tache de rouille dessus encore lol
_SPY_
DeeAzn83 wrote:pis ton produit anti-rouolle ca marche ya pas pas une tache de rouille dessus encore lol
x2 j'ai acheté les miens au début de l'été et zéro rouille, tous le monde pense qu'ils sont neuf meme aujourd'hui
NoRmAlGuy
merci les pots sa fait chaud au coeur ca dure a peu pres 6 a 12 mois le produit , mais au moins s'est deja ca de gagné!
NoRmAlGuy wrote:s'Est ma fete ( 21 septembre)
Bonne Fête en retard !!!!
NoRmAlGuy
merci!!!! 11 mois en retard ... vaut mieux tard que jamais
NoRmAlGuy wrote:merci!!!! 11 mois en retard ... vaut mieux tard que jamais
Tu veux dire 1 mois.
Je check pas ton topic à tous les jours, quand même.
Peux-tu me donner un prix pour une suspension complète Eibach Prokit 1.5'' de drop. Pour un Focus 2007 SE 4 portes, 2.0L DOHC Duratec Powa ?
Svp Merci. Je vais voir aussi avec Ford, à combien ils me vendent ca.
J'ai besoin de shocks et springs. Si tu peux avoir le kit avec sway bars, donne-moi le prix de ca aussi.
Gros Merci.
NoRmAlGuy
merci quand meme 31 ans ca se fete
NoRmAlGuy wrote:merci quand meme 31 ans ca se fete![]()
damn t'es rendu VIEUX !!!
M'a te rejoindre dans pas long.
@95exrv6
en passant, quand meme que tu metrais des brake de 18roue sur ta accord propulsion, si tes tire c'est 4saisons, tu brakera pas plus.... aussi faut que tu sache que des brake ont leur temperature "optimal" alors si tu met des "SUPPPER BRAKE DEBILE ECEURANT" 16 pistons come dans les magasine style "addx" .... tu va seulement avoir de beau brake.... qui vont braker un brin plus que du oem avec des pad hawk hp+.... si tu fait de la trac.... on parle de autre chose.. mais bon... je pence que tu as compris
@normalguy
salut mec
peu tu me sender un prix pour:
disque avant wagon slotté pas drillé
disque arriere plain
tout ca dans le Brembo
ainsi que un set de pad Hawk hp+ pour
legend 94 piston double avant
accord disque arriere
@normalguy
salut mec
